![]() | Home > General > Rear Wash Wipe |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
Mine only does one sweep if I don't activate the washer too. If I activate the washer function it wipes 3 times. I'm in the shed, I'll be back in the real world in a minute. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Same as you Russ though I find it annoying that you have to do 2 actions (on/off) to get it to sweep just once and if you want it to do a number of sweeps, then you either have to add water or click it on/off on/off on/off etc
Wow! I've just partly answered my own problem...
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Are you sure you don't have a fault with the motor/park switch ?
