![]() | Home > General > Quick Question about 2010-2013 Range Rover Sport AWD System |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
Hey guys,
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 ![]() ![]() |
Here is a good explanation of how the transfer box works.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Sport mode doesn't do anything to the diffs. RRS has a 50/50 split full-time all wheel drive with stock torsen centre diff aable to be fully locked with special programs and opptonal locking rear diff. Yes, it is somewhat similar to quattro, but much more adjustable due to terrain response. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Dynamic mode will only vary the steering weight, the monitoring of the suspension and the frequency that it adjusts and the throttle response, AFAIK in Dynamic no changes are made to diff locks. In Sport mode all that changes is that the gear box will hold onto gears to higher in the rev band until you pull the + paddle or it automatically shifts up when you get to the rev limiter, again it does nothing to diffs from my understanding. When I have been greenlaning on 22" wheels and road tyres it has surprised me how hard the rear difflock works even in not particularly challenging conditions on my L494 Dynamic, none of my previous FFRR's or RRS's had the e-diff and it is very effective on my present car in the Grass, gravel and Snow setting. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
So you're saying that in sport mode the power split stays 50/50 and not a 60/40 bias to the rear wheels? I gotta wonder about that because in an empty parking lot on a snow day, if I disable traction control put it in dynamic and Sport mode The car spins on a dine if I just mash the throttle. Even if I try to take off in a straight line the back end seems to want to kick out all the time. When back in "D" with dynamic off and traction control back on I can mash the throttle and even before TC kicks in the back end hardly kicks out when mashing the throttle. This is what lead me to wonder about the power split in different modes. |
It's because it moves forward, not reverse. Try the same thing in reverse and you'll be throwing your front end all over the place.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
The centre diff isn't a torsen unit, it's a normally open diff with the locking function provided by a multi plate clutch. The clutch is controlled by the Terrain Response system. The system can give fully variable locking. Each TR setting will give different locking characteristics.
I was under impression that the centre diff is a Torsen unit with additional electronic lockup control, but might be wrong with the actual unit used. Notwithstanding with any of the above observations. Regards etc.,
I think the L322 FFRR had a Torsen centre diff when first produced. It changed to the same system as the D3 / RRS when it took on the Magna-Steyr transfer box in 2008(?) along with Terrain Response etc.
Thank You all for your replies. RRSTDV8 seems to make sense here as I can't imagine the front wheels rising enough on a 50/50 power split to throw out the back end. Afterall, the front of these things are *very* heavy. Furthermore, it did not take a huge oomph of power to make the back end fishtail on a snowy surface. Keep in mind that I did disengage Everything and set up the car for what I thought would be full power to the rear wheels. As for Dynamic mode changing the steering weight, not in mys car. It's Hydraulic steering and I'm pretty sure that you can only vary steering weight on an electronically driven steering rack. Also, there is no change in the feel of the steering.
