![]() | Home > General > 2.7 reliability |
Go for it - belts are done and I am sure it will serve you well. 07MY RRS TDV6
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Hi Squizzel, firstly I'm very sorry for your loss. It's early days but things will look brighter in time I'm sure. As to your question, I'm on my second Sport, both being TDV8's so the engine is different but the running gear is broadly similar. Mine have been reliable over 100k miles of ownership with only issues being an alternator, battery, rear ARC bar and usual brake discs. You are right in that we hear more about failures than successes on the forum but that's only natural. I would suspect you will be okay if it has been maintained but expect the usual brake discs and battery (not overly dear) but the alternator is a bit dear especially the hours needed to change (although the 2.7 is less hours than TDV8). Electrics can play up and send weird messages to the dash but very often its just a brake bulb or brake light switch in the footwell that has packed up and cheap to replace. You could consider a warranty but watch the small print and I wonder if there are companies who will give realistically useful cover given the age and mileage - don't pay upwards of £600 per annum for a policy which gives limited cover - keep that money in the bank for a rainy day. Let us know what you chose to do |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Sorry for you loss |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
Thanks for the responses,
Phatcat Member Since: 27 Dec 2015 Location: Wetherby Posts: 12 ![]() ![]() |
Maintenance is the key to most things vehicle reliability wise and Range Rovers are no different to a point.
Can't you park your D2 up somewhere with no insurance/tax |
No I have no space for the d2 unfortunately, as I would love to keep it. i'me not new to land rovers, just the newer ones don't seem so diy friendly. The last 3 cars I have owned are range rover classic 3.9 v8, p38 4.6 v8 (that nearly cleaned me out), and the d2 TD5. I have always done all the work on them and although the sport has only done 1000 miles a year I have serviced it once a year including fuel filter. I fitted the alternator and the rear passenger door lock actuator, and done a driveshaft gator passenger front. I can do the blend motor (it can't be any worse than the p38) but the rest will have to be done in a specialist. I just don't want a re run of the p38, fix one thing another 3 went wrong, I had 3 engine rebuilds in that, but as I said earlier these don't seem so diy friendly. |
You have my sympathy, but cars and emotions don't mix.
Thanks for all the replies, and condolancies it is really appreciated.
AllTrack have a very good reputation so do these guys but not sure if they have a flush machine |
Hi DrRob I don't think they do. They are very good and reasonable priced as we have had work done with them before. In fact they did the cam belts on the sport for my dad. Although they may have got a flush machine since I last spoke to them, a phone call isn't going to hurt as they are a lot closer to me. |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Look at it with some cold logic.
I'me not changing things over just yet, I have to sell mine yet and I wont do that until after everything has settled, so I am looking at the end of March really to put mine up for sale. I have used the sport to keep it running ok, my dad broke his hip 3 years ago and never drove again, so the 900 miles a year was done by me. I do around 5000 miles a year total. Anything that needed doing even regular servicing was done even though it only did the low miles. when he had it, the jobs that had to be done were, front suspension bushes, new uprated compressor, and tailgate lock. That was September 2012, since then I have fitted rear passenger door lock, Clock spring, Alternator, aircon regas, and a full set of tyres. In a garage it had the cam belts done new disks and pads and EPB shoes, Other than that its been serviced regular (including fuel filter). Jobs to do are Gearbox flush, passenger blend motor, and a new screen. I have a hawk eye diagnostics tool, I have a fault mate for the D2, but its locked to the chassis number of the disco, I have been in touch with black box but to change it over is quite expensive, in fact its cheaper to buy the new hawk eye that fits all the land rover models. It will be ok for what I need.
My Disco 2 sold today, so I will be changing everything over tomorrow. The sport has been standing now since the middle of January. I had it running a week ago and the battery was low, so it threw up loads of faults but its just down to low power. We have a couple of hospital appointments over the next couple of weeks then its getting booked in for a gearbox mega flush. We just have to see how we get on with it now.. |
