![]() | Home > Maintenance & Modifications > Safe to Trickle Charge? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
we send to use CTEK chargers which you can leave plugged it stops charging when the battery is fully charged |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 206 ![]() ![]() ![]() |
I use cteks on all my cars in the garage except the daily driver, makes a world of difference and highly recommend. 2018 Telsa MS
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
I would consider replacing the battery if you haven't replaced it recently, I was having constant power issues (stereo freezing up, parking fault codes, occasional flat battery) and had to keep it on charge if I wasn't using it everyday, after a new AGM battery for £180, it seems a lot better behaved. Time will tell, but so far it's a lot better.
Or
If you have tow electrics then buy an adaptor on here and charge it via a ctek through that |
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 ![]() ![]() ![]() |
CTEK chargers ! I use one on my RRS and My 335D |
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html Visitor from fullfatrr.com
