![]() | Home > General > Tow Bar troubleshooting... |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I don't know the answer to all of your post, but the little pin you talk about, IIRC, is the thingy that releases the locking pin once you tow bar is pushed fully home.
adamm19830 Member Since: 21 Mar 2015 Location: Nottingham Posts: 45 ![]() ![]() ![]() |
Thanks Eaters,
Hmm. Does sound crock! However I'm only talking from memory, and may have got it wrong. I think the little pin sticks up about a quarter to three eighths of an inch before you hit it. Only needs a gentle tap.
Thanks for that. Do you know if you can manually move that little pin up and down with your fingers? I can move mine up and down a good 5mm, I don't think I should be able to..... |
No, cant move it at all with my fingers. I think yours is b |
Oh great!!! 👎🏻👎🏻👎🏻👎🏻 Thanks for the help. I guess I'll be buying another then! |
crocs Member Since: 22 Jan 2017 Location: Ayrshire Posts: 115 ![]() ![]() ![]() |
Not sure if it covers your car, but there was a recall for these tow bars.
On further thought I think I could possibly access the tow bar internally to see if the little pin could be fixed by removing the "blanking plate" on the opposite side to the lock. A long shot though |
If your only other option is a replacement, it might be worth seeing how much further you can dismantle it. What have you got to loose |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
How much do you want for it I have a half broken one I would like to fix 61 AB 5.0 supercharged rocket
