Home > Maintenance & Modifications > Random battery light |
Remove the charging circuit fuse and check it, check the alternator connector.
Sun Feb 05 2017 10:43am |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Hi bodsy 👍 Is the charging fuse the one on positive battery lead by connector, if I remember correct it was 12.3v after leaving over night and checking in morning, and 14.3v min and 14.7v max when running and playing with heater/lights/etc, didn't actually think of checking when light was on, good idea makes sense now you said it, ha, will check later, knowing the sport it won't come on now I want it too. |
Sun Feb 05 2017 11:09am |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 536 |
Gilly,
Mon Feb 06 2017 7:09pm |
Hi scrumps, thankyou kindly for your message, I'm working away all week but when I get bk will be giving all a good check over the weekend. Will def be starting with loose connections. Hopefully will be lucky. |
Mon Feb 06 2017 7:26pm |
Took the sport for a drive today and airbag light came on as well as battery light, then window washers stopped working all other wiper functions worked ok ( auto on, manual speeds all ok,) then all suspension sensor indicators on 4x4 screen went red, they cleared after switched off then on again. So got home and checked volts with meter and battery was 12.3v with engine off and 12.5v with engine on went up to 13v when revved, so think it's new alternator time and fingers crossed it will clear the other faults. |
Sat Feb 11 2017 1:59pm |
Hi, can anyone please confirm this is correct for my 2006 sport 2.7TDV6 please, (BIT CONFUSED if I've got ACE)
Sat Feb 11 2017 3:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
doubt you have ACE.
Sat Feb 11 2017 3:54pm |
Sat Feb 11 2017 3:58pm |
yeap, ok you do have ACE then. |
Sat Feb 11 2017 4:03pm |
Lol, thanks mate, do you no best place for alternator. |
Sat Feb 11 2017 4:04pm |
not really.
Sat Feb 11 2017 4:10pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Advanced Factors are site sponsors and there is a discount code somewhere....
Sat Feb 11 2017 4:28pm |
Will do, that's great, thanks, (got to love a discount code ) |
Sat Feb 11 2017 6:05pm |
