Home > Technical > Judder at low revs
Miller
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Judder at low revs
I have judder when cold at idle and when pulling away, after everything is warm it goes.
It's 2006 tdv6 at 79,000 miles.
reading through the forum seems I need to get a gearbox flush, can anyone recommend somewhere near bath / Bristol area??
Thank you[/s]
Post #517414 Sat Feb 11 2017 1:53pm
DrRob
Highly rated but not sure if they do flushes http://www.bristoltransmissions.co.uk/home/
AllTrack in Malvern do flushes Visitor from fullfatrr.com
Post #517415 Sat Feb 11 2017 1:56pm
Miller
Thank you will email Bristol transmission
Post #517416 Sat Feb 11 2017 1:59pm
Disco_Mikey
If you have a judder, a flush will not cure it permanently. It may cure it for a few thousand miles, but it will come back
IMHO, bite the bullet and go for a new torque converter before it does any long term damage s
Post #517435 Sat Feb 11 2017 4:44pm
Miller
It's only does about 3000 miles a year , so will try the flush first as may be good for another 2 years
Post #517436 Sat Feb 11 2017 4:52pm
TheWojtek
Or next 30 miles, should your TC decide not to collaborate anymore. If it judders, it's one serious kickdown away from failing. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #517468 Sat Feb 11 2017 7:36pm
erickwan
Malaysia
Had this as well, except it shuddered a little less when warm. Used Shudder Fixx and it's been good for the last 25,000 kms, touch wood.
Post #518230 Sun Feb 19 2017 2:34pm
