Home > Detailing & Car Cleaning > Karcher SnowFoam |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4993 |
Hi.
Fri Feb 10 2017 3:24pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2794 |
I went for one like this - holds more foam for the bigger car
Fri Feb 10 2017 3:35pm |
God I'm never gonna buy one at this rate.
Fri Feb 10 2017 3:52pm |
The Ebay dispenser is made up as required for different pressure washers & capacity requirements. I've had one for three years with no issues. I've always used the low Ph - high priced snow foam - I can see why you would want to keep the cost down if your only going to use it 4 times a year but the dispenser can be used for shampoo as well
Fri Feb 10 2017 4:05pm |
The car has been clayed and waxed.
Fri Feb 10 2017 4:33pm |
IMO snow foam is overrated unless used with industrial high powered hot pressure washers - it may take some residue of dirt off but doesn't create a fresh clean look unless of course I've been using it wrong for the last 4 years 16MY Estoril Blue SVR.............
Fri Feb 10 2017 4:41pm |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 |
Ive got one of those ebay guns, works really well. It seems to be a copy of a much more expensive branded one (chemical guys or meguiars or something) and was the recommended gun on detailing world. I use it with some 'autobrite magifoam' which seems to work pretty well, I leave it to dwell for about 10 minutes then blast it off and it makes a difference.
Fri Feb 10 2017 4:50pm |
Ok I will look at the ebay one more seriously.
Fri Feb 10 2017 4:54pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
I got the one with the knob on top and works well, got it from Halfords for around £12, I am using Gtechniq W4, removes most of the dirt so very little dirt ends up on the mitt. |
Fri Feb 10 2017 5:17pm |
Ive got one similar to peachy's & had it about 7 years,,the snow foam I use is valet pro PH neutral as it doesn't strip the polish or wax off the car..in fact Ive just done my truck about a hour ago.
Fri Feb 10 2017 5:46pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Neither of them, you will just get white water, they are only good for things like patio cleaners, but as for producing foam, no chance. Get one of these, http://www.in2detailing.co.uk/products/was...tings.html And just ask the guy to Ptfe the fitting for you. Ps snow foam is meant as a prewash, something you do before every wash, to help remove any crap before you actually stick sponge/mitt to paint work. Plus 1 for valet pro ph neutral snow foam, also bilt hammer auto foam comes highly recommended Wearing VAlet Pro ph neutral snow foam. [URL=]
[URL=]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Fri Feb 10 2017 5:52pm |
Kermit1970 Member Since: 26 Nov 2016 Location: Ayrshire Posts: 8 |
The genuine karcher one is useless. Get a variable snow foam bottle as the boys say. Been using them for years. Just order a spare filter gauze. |
Fri Feb 10 2017 10:20pm |
Ok I have gone with your advice guys
Sat Feb 11 2017 4:05pm |
You won't be disappointed Andy K,,best thing is put warm to hot water in bottle then add the snow foam.
Sat Feb 11 2017 6:55pm |
