![]() | Home > Technical > Definitive answer required |
Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 161 ![]() ![]() ![]() |
Hi all
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I think it works for the first spray with the lights on.
Fuse 7 in engine bay. 30A |
thanks, I'll check that one in the morning |
Thanks I'll source a pump after trying the fuse. But I'm guessing if they are in the same unit, both would fail if the fuse blows |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Sorry, I did the pump on the second car the other week and confused myself.
Can confirm its not the fuse.
bit premature but got stuck in
Pump replaced today, I am now able to spray my headlights all working well, and really good pressure |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
Result Paul, well done |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
Hey Paul where did you order the pump from??? Can you please post the link to the exact pump you bought and the site you bought it from?
I rang my local Land Rover dealer, and collected the following morning. |
