Home > General > key fob issue
danboy
key fob issue
Right chaps
so got the new car (2007rrs HSE) the key fobs both worked fine, unlocking/locking ect, but were in really poor condition, si from flea bay got 2 new cases, bit tricky but changed them and they look great, then, because in silly thought (hmmmm, being 2007) the rechargeable batteries must be getting tired, i know ill change them !!!
so ordered the correct batteries and decided to do one ( make sure it works ok then do the other)
so de-soldered the battery, fitted the new one and hey presto !!! it DIDNT work, it would start the car but would not lock or unlock the doors, i sweated a little, but thought maybe the battery was flat, so started the car with the key and we drove it about that day, here and there, that evening i tried to lock the car with the key and it worked, tried it several times and worked every time.
i didn't then move on to the other key as i thought caution may be the name of the game, so though id leave it a week or so before doing the other key just to make sure that the key i had changed the battery in was going to work without issue over a few days.
however it will now not lock or unlock the doors again, the key starts the car as before but will not unlock / lock the doors.
so looked online and tried the, (ignition on <5sec. hold unlock, press lock 3 times ect but this didn't fix it either.
can anyone help !!!????
kindest regards 2007 RRS HSE
Post #514354 Fri Jan 13 2017 12:14pm
refit the old battery and see how things go ?
Post #514356 Fri Jan 13 2017 12:24pm
danboy
can't !!! launched it !!!lol 2007 RRS HSE
Post #514358 Fri Jan 13 2017 12:34pm
get another from somewhere else. Amazon ?
Post #514367 Fri Jan 13 2017 1:55pm
Tim in Scotland
Try member RRUK's service in the For sale and wanted section 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514372 Fri Jan 13 2017 2:31pm
Paddi
The battery you installed could be faulty but it sounds as if you haven't given it much opportunity to charge up. Try strapping it to the working fob and running around with it like that for a week. Alternatively, rumour has it that resting the fob against your electric toothbrush charger overnight is effective. 2008 MY Java Black TDV8 HSE
Post #514379 Fri Jan 13 2017 3:15pm
danboy
hi chaps,
just a quick update.
got so annoyed after replacing the battery and it not working so trawled the net and decided to send it to keys2u.co.uk and for a price of £38 they guarantee a full repair to the board, new battery and case if required, i received it back through the postal system in less that 24hrs and it works perfectly. well chuffed. 2007 RRS HSE
Post #516855 Sun Feb 05 2017 2:54pm
panda
Not saying anything about keys2u but did you get it sent to address where car is kept??
Post #516858 Sun Feb 05 2017 4:12pm
