![]() | Home > In Car Electronics > Wiring up a reversing camera to aftermarket head unit? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5105 ![]() ![]() ![]() |
Note you have Logic7 with an amplifier under the seat.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
I think InCarTec now do a kit for the Logic7s. The instructions have you break down the the HU and remove the SatNav/Steering part, which you then hide behind the new HU.
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
I used slightly different approach and located reverse light feed in rear quarter panel of boot on left. The connections for towing electrics are here to quite easy. Used this for positive power and also took earth from there up to roof where i connected the earth to the camera earth and reverse feed to both camera +ve and the red power wire than runs inside coax.
W44NNE Member Since: 30 Nov 2016 Location: North West Posts: 67 ![]() ![]() ![]() |
Excellent advice, thanks. I wish I'd read this sooner as I ran a dash cam rear camera cable the other day and decided to go down the side of the interior. The roof lining option sounds neater. |
