Home > Maintenance & Modifications > Flat battery after holiday away
jamesbilluk
Hi all,
Me and my partner recently returned from a 2 week trip away, and returned to the RRS (2010 TDV8) in the car park.
It unlocked fine, but when i trued to start it, the instruments were just twitching, and various warning signs were being displayed. It didn't get to the point of saying "cold start in progress" I called the AA in the end, and he started it using booster, and his fan plugged into it as well. From his checks, he said it looked a new battery, so couldn't have been that. Just wondering what the problem could be? this would have been the longest time I've left the car,
Many thanks
James. 2010 Range Rover sport TDV8
Post #516382 Tue Jan 31 2017 4:03pm
They don't like being left.
If you want to leave it in a car park again, get a big solar charger (ebay)
or if you leave it at home, use a CTEK charger to connect to the mains.
Post #516393 Tue Jan 31 2017 6:09pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
I concur on the CTEK chargers, i've just bought a new battery. 2 weeks later i bought the CTEK and plugged it in after not using the car for 2 days and it showed the battery was ½ full. An overnight trickle charge and it was 100% in the morning.
2 days later a run up the motorway at 110km/h for 75 minutes.
then left car for 2 days at -2 degrees C. plugged in CTEK and showed battery was again 50% charge. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #516395 Tue Jan 31 2017 6:15pm
jamesbilluk
Thanks guys Smile
Ill pick up a CTEK for home, and a solar charger as well to put in the boot for when its going to be left up in a car park for a longer period.
Post #516396 Tue Jan 31 2017 6:23pm
In fairness CTEK's always find something to do! (in the need to charge the battery).
What is more of an indication is
1) The starting voltage of the battery. A CTEK indicator lead/plug will tell you that with 3 coloured LEDs
2) The time taken for the CTEK to complete to green can give you a rough guide.
Post #516397 Tue Jan 31 2017 6:24pm
You will need a decent sized solar unit.
e.g.
http://www.ebay.co.uk/itm/4-Watt-12V-Solar...Swu4BVue-q
And a way to connect it up to the battery.
The cigar lights are disabled with the ignition off.
Post #516398 Tue Jan 31 2017 6:26pm
jamesbilluk
Many thanks Andy,
A CTEK will certainly come in useful for my other car too (TVR) which seems to drain its battery regularly too!
Thanks for the link too, the solar trickle charger looks great.
Post #516399 Tue Jan 31 2017 6:39pm
We like the CTEK 5 around here (with red button)
See here
http://www.ebay.co.uk/itm/CTEK-MXS-5-0-12v...Sw0e9Usn~F
Note this deal has an additional indicator lead (worth £5) which will be very useful if you are going to use the charger on a 2nd car.
Post #516402 Tue Jan 31 2017 7:30pm
If the OP's battery was the original fitment then it was probably ready for a change anyway. Be worth getting the alternator output checked too. 2012 SDV6 - it's missing a couple of cylinders
Post #516404 Tue Jan 31 2017 7:37pm
d-9
The screw on indicator leads are really useful because it saves you removing the battery cover everytime you want to put the car on charge.
Post #516406 Tue Jan 31 2017 7:45pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, ours does not get much use really, but i do find a overnight trickle works wonders once a week, especially over the winter months Thumbs Up (Lidl smart charger, £13,00 works brilliant) Bow down 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #516415 Tue Jan 31 2017 10:33pm
