Home > Technical > parking sensors
Wayneclarke
parking sensors
just reversing on the drive and the parking sensors were making a weird beeping not the normal tone and didn't even flat line when i hit the mrs Mercedes ( oops ) any ideas ???
Post #516278 Mon Jan 30 2017 1:22pm
Macca
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Could be one or more of a few causes, most likely place to start is faulty sensor, check if all are 'ticking'...could be internal short of a sensor, if no joy there check the wiring a few good read ups on here.If you have, or can get access to an IID tool or similar would certainly help pinpoint. Ive had both a faulty sensor (easy to find) internal short on one (not so easy) Good luck Thumbs Up D3 TDV6 SE auto 2006
FFRR TD6 vogue SE Overfinch 2006
RRS TDV6 HSE 2007
L322 4.4 TDV8 Overfinch 2012
Post #516285 Mon Jan 30 2017 2:54pm
Wayneclarke
thanks , just been out and started the car up put it in reverse and seems to be working fine now , god knows whats going on there. but thanks anyway
Post #516306 Mon Jan 30 2017 5:42pm
KernowRRS
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Wet weather is not nice to the sensors, also apparently jet washing does them no favours
Post #516307 Mon Jan 30 2017 6:21pm
Eaters
I concur with Kernow. I have intermittent (annoying) fault with mine which manifests itself after driving in wet weather Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #516315 Mon Jan 30 2017 6:56pm
KernowRRS
You would think something like Rain would be factored into a parking sensor!
Post #516316 Mon Jan 30 2017 7:05pm
Some systems give an error tone if there is a problem when you first select reverse.
So if its a different tone, that could be it, and dn't rely on them
Post #516320 Mon Jan 30 2017 7:43pm
Wayneclarke
cheers for the info guys
Post #516323 Mon Jan 30 2017 8:12pm
Eaters
Just for clarity, and in case it's of use, the parking aids on mine have 3 tones. High pitched bleep means front sensors give picked up something, a lower pitched bleep is the rears. If you get a continual high tone for about 10 seconds and then the parking aid switch light flashes, then that's telling you that they are not working.
Also I don't know what happens if, say, you are reversing towards a wall and at the same time the front is near, say, a hedge. Don't recall getting both tones on mine so one must have priority. Question Robin
Gone:
MGZTT 190 2.5
Post #516351 Tue Jan 31 2017 12:22am
I think you do get both tones on early cars.
If you have parked close to something nose in, and then need to reverse out you get both.
Post #516366 Tue Jan 31 2017 1:05pm
jakoh
United States 2006 Range Rover Sport 4.4 V8 HSE Lux Bonatti Grey
How do you find one with an internal short?
My front beeps all the time, my guess it is a short.
if connector is loose will that cause a always on beep?
Post #525830 Wed May 10 2017 6:48pm
A short would knock all of them out and incase of the fronts give an error on the dash.
Post #525839 Wed May 10 2017 8:15pm
jakoh
problem statement, front always beeps regardless.
So i verified that they all make the clicking sound.
My guess is one of the sensors cables is shorted by water in the connnector.
I can with some dificulty get to the side sensors and unplug and replug them.
the middle two i have no idea. any help there would be nice.
Post #525879 Thu May 11 2017 5:32pm
water can also get into the sensors.
Options are
1) get an expensive fault code reader and see which one is reporting a problem/short distance
2) buy a replacement sensor, (can get them cheap in europe/china) (or even 2 if they haven't been working for a long time) and remove the bumper, and swap a new one out, one at a time and see if you can sort it.
As yours always has a problem, you stand a good chance
Post #525881 Thu May 11 2017 5:37pm
jakoh
Got it, i will buy a sensor and proceed.
I just need to figure out how to get to the middle two, later.
Post #525882 Thu May 11 2017 5:48pm
