Home > General (L494) > Compressor Running Time (noise) |
Could it be possible that there is a small leak where the apprentice assigned to do the job hasn't put in a washer/ O ring or nipped up a connection quite tight enough? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jan 27 2017 9:54am |
ChunkRRS Member Since: 20 Dec 2016 Location: Scottish Borders Posts: 154 |
just my 10 pence but you mentioned new software added
Fri Jan 27 2017 10:18am |
JBJSY Member Since: 27 Jan 2017 Location: Jersey Posts: 12 |
Thanks for the comments...
Fri Jan 27 2017 11:26am |
You have another route of investigation: contact Land Rover Customer Services through the section on the forum and ask the person to pass your message on to the technical people. The LRCS person will require your details and car details and the details of the issue which as you have only 2 posts so far you will have to do by phone or by email as you have too few posts to use the PM system (5 post required before you can use them), you also don't want to give name and address details + VIn in open forum.
Fri Jan 27 2017 1:33pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
At night put it in off road height and see if it drops at all. The longer you can leave it the better. |
Fri Jan 27 2017 2:00pm |
Thank you for your comments. I will try the off-road height over night and also email LR and see what comes back.
Fri Jan 27 2017 3:10pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Definitely should not do that.
Fri Jan 27 2017 9:06pm |
A thought - could a faulty suspension height sensor make the compressor run constantly? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Sat Jan 28 2017 8:43am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1671 |
If the ride height is normal then it sounds like a leak, as Tim suggested. |
Sat Jan 28 2017 9:36am |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
On mine I have so far have heard the noise of parking brake working, gearbox parking selector motor working (all very faint from inside the car) and so on but have not heard the air compressor working so it certainly must be quite noisy for you to hear it working.
Sat Jan 28 2017 12:22pm |
Thanks again everyone.
Sat Jan 28 2017 12:41pm |
Once the pressure is up to working pressure it should stop. Are you getting any warning on the dash that the compressor is overheating - that is usually a sign that it is running continuously for some reason or you have been raising or lower it a lot? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jan 28 2017 12:54pm |
Thanks Tim - no warnings on dash. No lights. Westover suggested it would be easier to diagnose if there were warnings on. Fiar point! Land Rover addict |
Sat Jan 28 2017 1:08pm |
Just read the workshop manual, it doesn't say any durations of working, but as system has a Air reservoir with 16L capacity, once the car has been raised it sounds like the compressor doesn't need to work until its lowered and raised again. I actually managed to raise the car to off-road height using the keyfob and that was done with the air from the reservoir so I tend to think that if there' no leak, then air compressor may not be working correctly, either not reaching the correct pressure or the required volume to fill the Air reservoir.
Sat Jan 28 2017 1:15pm |
