Home > Maintenance & Modifications > FBH Quesgution
mgriggs
United Kingdom 2012 Range Rover Sport SDV6 HSE Nara Bronze
FBH Quesgution
Hi Guys,I have timed climate enabled on my FBH will it still come on if the temp is below 5dec automatically or will it only work on the timer? 2012,Range Rover Sport HSE,SDV6,Nara Bronze,Cold Climate Pack,Memory Pack,Dynanic Pack
Post #515926 Thu Jan 26 2017 5:47pm
Bodsy
Site Sponsor
It will come on when the car needs it. The timer will get it to come on below 14 degrees, the car will get it to come on at 5 although it could vary by a few degrees.
You can also get a remote kit for it, very useful when you forget to set the timer! Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #515935 Thu Jan 26 2017 6:18pm
mgriggs
OK thanks Bodsy I need to get it check out them as it has not come on in this cold weather,may be it has locked out,do,you now how I can reset with the IID tool? 2012,Range Rover Sport HSE,SDV6,Nara Bronze,Cold Climate Pack,Memory Pack,Dynanic Pack
Post #515936 Thu Jan 26 2017 6:31pm
