Home > General > New Owner - list of questions! |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Congratulations on the new motor. I have a MY 2011 poor-man's diesel, so I can answer some of these.
Mon Jan 23 2017 10:54am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
The pre-facelift RRS had this smart shortcut of "touch anywhere on the map → select 'Home' icon", perhaps your satnav still retains it? Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Mon Jan 23 2017 10:59am |
In Stored Locations add the home address and then you can press to talk and say "NAVIGATION GO HOME". I do not use this feature. Manually it would be Menu > Destination Entry > Home.
Mon Jan 23 2017 11:20am |
crocs Member Since: 22 Jan 2017 Location: Ayrshire Posts: 115 |
'Navigation, go Home' works for me. It's really useful if you'in an unfamiliar city centre, otherwise you'll probably know the way home.
Mon Jan 23 2017 6:01pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4970 |
It is posible to buy just the front perspex part from L/R and easy to change, however you will need to remove the instrument cluster to do it which can be a bit fiddly, easiest way is to remove steering wheel first. Cheers Col |
Mon Jan 23 2017 10:11pm |
Lunar_Lamp Member Since: 14 Jan 2017 Location: UK Posts: 9 |
Ah, thanks Col - this sounds like it's an irritating job to do, but may well be worth it for me.
Mon Jan 23 2017 10:41pm |
I'll dig the part number out later and add to post for you, just enjoying 30 degree sunshine on the beach at the moment.
Tue Jan 24 2017 12:50am |
Part Number: LR041042 retails around £85.00 with vat. expensive bit of plastic, but inline with L/R rip off prices.
Tue Jan 24 2017 3:18am |
Thanks for that Col!
Tue Jan 24 2017 10:15am |
