Home > Wheels & Tyres > 4 Wheel Alignment after rear A.R.B being changed? |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
My indy, LRR in Charlton, didn't get my car aligned when they changed the rear ARB (ACE) last month. I asked when I collected as I had inside wear N/S/F tyre when I changed tyres last month. They said that it wasn't necessary. However, when they did the front ARB(ACE) they did do so and something else on the front they worked on, without asking. |
Fri Jan 20 2017 1:39pm |
Andi2707 Member Since: 24 Nov 2016 Location: Kent Posts: 10 |
thanks for that Pufftmw. |
Fri Jan 20 2017 2:10pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
For the cost of having it properly done, and the money you'd save on tyres, I'd say go ahead and have it 4 wheel aligned after the work. Make sure you have it done somewhere that has the proper Hunter (or equivalent) equipment. Dealer is best but they do tend to charge more. I'm in the shed, I'll be back in the real world in a minute. |
Fri Jan 20 2017 3:49pm |
Hi Russben. Thats kind of what i was thinking too. Local garage charges £50 for 4 wheel align using Hunter equipment. Im going get it booked in.
Fri Jan 20 2017 3:55pm |
My local tyre fitting garage couldn't seem to get mine set right for some reason, as a consequence it wore out tyres rather quickly.
Fri Jan 20 2017 4:11pm |
