![]() | Home > Photos, Videos & Media > Disco5 off-roading in Arizona |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9035 ![]() ![]() ![]() |
RRS1 might struggle with ground clearance a touch. The D5 and RRS2 have more clearance as standard. Other than that, agreed. 2012 SDV6 - it's missing a couple of cylinders
Not with the iid tweaks |
Even then I think Chris, although not entirely sure. Either way, the D5 driver doesn't need an IID to get big clearances... |
226mm Vs 283mm for Disco 5. Add another 50mm to the 226mm on the iid and your not far off on ground clearance. If you then factor a bit more in for the rolling radius of a 55 profile A/T tyre and I would say your about there |
Maybe be we need a forum outing to try out a comparison - standard RRS v iiD upgrade v L494 standard?
