![]() | Home > Maintenance & Modifications > Help...... Central locking stopped working |
Maybe start with the easiest checks first?
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Thank you for the advice.
I am thinking that I may need to seek out someone to read fault codes for me, but before I do, does anyone have any thoughts as to what can be happening?
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
I had similar symptoms, and the dealer ordered a new module, but I cured it by taking out the relevant fuse and putting it back again. However, as you have already disconnected the battery maybe that won't work and it really is the module. |
Wow, that is helpful.
Sorry, no. I forgot to say that this phenomenon struck again a few months later, was cured the same way (with fuse removal), and never happened again, (but that's probably no help to you!). As a guess, I'd suggest the module may be under the steering column, as that's where you have to put the key if you are having problems with key recognition. |
No that is very helpful actually. I will have a look at it this weekend (if it isn`t too cold outside). It is too difficult to mess around in the dark in the evenings.
I am still trying to overcome this problem. To save me a lot of dismantling work, does anyone know the location of the central locking control module?
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Did you try pulling the fuse ?
Ah brilliant. I assume you mean touching the disconnected live and earth terminals?
Thats the badger |
Badger?? I have enough trouble with Ratty and Moley. |
