Home > Technical > Suspension incorrectly detecting grounding |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
I took this in to my local independant who plugged it into the computer, no faults showing and everything acting normal. They said this can happen if the car has been used at road height most of the time and is then used off-road for a bit, because the height sensors corrode at the higher settings, then give spurious readouts. |
Thu Jan 12 2017 2:18pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Most likely caused by a poor calibration, or blocked compressor dryer |
Thu Jan 12 2017 2:32pm |
Thanks DM, is the compressor drier user serviceable (checkable?) or should I take it back to the garage... |
Thu Jan 12 2017 2:35pm |
