Home > Technical > GAP IID Tool settings questions
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi
I was cycling through my IIDTool options just having a nose around, and to see what was selected or not for me car. I've a couple of queries on the towing settings as I have the 12N & S electric setup, but the IIDTool says my car is setup for the 13pin, so would it be better changing to 7-pin? I must say that everything appears to work at the moment so maybe a case of leave well alone? I may convert to 13 pin shortly anyway to save faffing with adaptors for my newer trailer.
Also for the Trailer Stability Assist it says Undefined, is this something that I can turn on/off or must something have been installed to have it active? I tow both a 3.5t trailer and 1.8t caravan so any help by the car for stability would always be appreciated..
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #513460 Tue Jan 03 2017 6:34pm
Bodsy
Site Sponsor
If t works, leave it. Trailer stability assist is only with the full surrround cameras. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #513491 Wed Jan 04 2017 12:24am
insiorc
I'll leave it as is then, thanks.
Post #513492 Wed Jan 04 2017 12:27am
insiorc
Another IIDTool question
For the DPF, is it normal to say the remaining volume is 0.0L? To me that implies it is full, but I've not had any lights or warnings, and due to where I live all runs are pretty short, infact I'd struggle finding anywhere I could drive a speed over 30mph for more than 5 minutes.
Does it all look ok from these pics?
Thanks
Post #513878 Sun Jan 08 2017 6:43pm
