Home > Technical > Fuel leak off tube
airwolf222helicopters
Fuel leak off tube
Hi guys
Have problem with fuel leak off tube leaking on to exaust (battery side ) passenger - it is coming from last injector could be internal O ring or split pipe won't know until I start
Brought new part which comes complete for the 6 injectors and fuel temp sensor (pain in arse not in sections ) is there any tricks getting at these without stripping a lot down ?
I think if the injector wiring carriage is removed is best plan of attack ? Would like positive thoughts from anyone who has carried this out please
Also is it advisable to get 6 R clips that hold fitting to injectors or is there a way to remove and replace without damaging the new O ring just in case
Many thanks in advance Thumbs Up
Post #513471 Tue Jan 03 2017 8:50pm
The front ones are a pain due to the ridge tube to the centre of the engine.
However as it's a rear it will be much easier to just fix the problem rather than remove the whole dam pipe.
Seals and siemans/VDO connectors are available for the rear injectors on ebay.
use hair dryer to warm up the pipe first if you need to remove.
http://www.ebay.co.uk/itm/Volvo-C30-2-0-D-...SwFqJWn51-
http://www.ebay.co.uk/itm/SIEMENS-DIESEL-C...SwV0RXrI1t
http://www.ebay.co.uk/itm/FOR-LAND-ROVER-2...SwnGJWTFuB
http://www.ebay.co.uk/itm/Siemens-Common-R...Swd0BVt8~e
If it has this modern clip, you just press down on the protrouding part to release the clip.
Much better than loosing the old design Rolling Eyes
http://www.ebay.co.uk/itm/FORD-PEUGEOT-CIT...SwKfVXD2tY
Post #513474 Tue Jan 03 2017 9:23pm
Many thanks really helpful Andy
I'll look at clips tommorow and see if I can get a pic easily and I'll post it up in situ
And you could guide me if they are new version . From what I can remember looking yesterday once pin in if I looked other side it looked as a little bit of both prongs protude a bit and one of them looks bit bent ?
But I'll take pic tommorow
Post #513475 Tue Jan 03 2017 9:51pm
Hi guys this is best pic I can take until I start at weekend
What type are they push down or pull out clips ?
Post #513560 Wed Jan 04 2017 7:00pm
pull out.
Maybe worth ordering a spare as they are easy to drop/loose Rolling Eyes
Post #513571 Wed Jan 04 2017 8:21pm
Thanks Andy
Great help , are they easy to push back in - obviously once conector in postition just gently push back in or is it a jiggle because it looks as if in pic it has one pin bit bent ?
Post #513579 Wed Jan 04 2017 9:25pm
They go back in ok.
The clip can go back in first and push the connector past the clip.
Post #513580 Wed Jan 04 2017 9:50pm
Ta muchley !!
Your a star Thumbs Up
Post #513585 Wed Jan 04 2017 10:23pm
