Home > Technical > High Level Brake Light
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
My high level Brake light is starting to play up a bit, I am going to remove it and check the connection first. Failing that is it worth opening it up to try and repair. Is it an Led strip that is inside the lamp ( any pictures anyone ? ).
Failing that any suggestions on best place to buy one.
Cheers Jock. Thumbs Up
Post #512445 Fri Dec 16 2016 9:46pm
Down&Dirty
Flebay has them Thumbs Up
http://www.ebay.co.uk/itm/Genuine-Range-Ro...SwJ7RYUT1o Currently MY16 Disco 4 Mr. Green
Ex RRS MY13
Ex Discovery 3 MY08
Post #512448 Fri Dec 16 2016 10:00pm
Jock 77
Re High Level Brake Light
Thanks for the reply Thumbs Up
Do you have any ideas of what is inside these as in Led strip or bulbs.
Cheers Jock Thumbs Up
Post #512450 Fri Dec 16 2016 10:15pm
LEDs I think.
How do u know it's the light unit?
Post #512454 Fri Dec 16 2016 10:36pm
Jock 77
Hi Andy thanks for the reply.
If it doesn't work when the pedal is pressed, Give it a rattle with your hand and it comes on and works for a bit then stops working again.
That's why I was going to check the plug connections first ,if not wondered if it was a bad connection inside the casing.
cheers Jock Thumbs Up
Post #512456 Fri Dec 16 2016 11:13pm
Pufftmw
How much?! Shocked
One of my LEDs has stopped working in the strip and it annoys me every time I see it's reflection in a bus/coach behind me - but not that much!
Post #512602 Mon Dec 19 2016 1:37pm
