![]() | Home > Technical > Dreaded red low Battery Warning Message on main screen. |
The last couple of days I have had some sort of "Warning" flash up on screen in Red that fills TV/Map etc screen, but it doesn't stay on long enough to grab more than a couple of words (batteries possibly) before standard screen hides it and it disappears.
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
John,
Thanks guys, yes Tim I have the IID BT tool so will get it plugged in over weekend.
I'm surprised this isn't covered under JLR warranty Johnski, when this happened to me last winter they replaced the battery with a new AGM and said that they did a software upgrade to the Battery Monitoring System, although I suspect that they just reset the BMS and the battery was just dead.
Thanks Buckster. |
Tim, No faults listed using GAP IID BT Tool unfortunately. |
