Home > Maintenance & Modifications > Replacing ACE pump
RobbieRangeRover
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Replacing ACE pump
Need to replace the ACE pump on our 2007 RRS TDV8. Access looks a little tight. Anyone got any experience of doing this?
Post #512208 Tue Dec 13 2016 3:07pm
Socast
I've done it on the 4.2 SC and it's not too bad. You need to remove the wheel liner and a small part of the under tray. Not sure if the pump is in the same location on the TDV8 though.
Post #512388 Fri Dec 16 2016 1:55pm
According to the book of lies, you need to remove the cooling fan and the generator (alternator) to change the dynamic response pump.
Because the TDV8 is too big for the engine bay, everything is more involved! 2012 SDV6 - it's missing a couple of cylinders
Post #512403 Fri Dec 16 2016 3:39pm
