![]() | Home > General > RRS fan switch |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I suspect you are mistaken. |
Brisy007 Member Since: 13 Dec 2016 Location: \brighton Posts: 4 ![]() ![]() ![]() |
Can you elaborate please Andy? |
Cars don't tend to have a switch these days. They use the ecu temperature sensor and the ecu controls it.
Thanks Andy, to be honest I'm not clued up on this sort of thing'should the fan be running all the time, how can I tell if it has a viscous fan?
There is also a fan (IIRC for the gearbox oil cooler) that can run briefly after start up and is quite audible on cold days. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Think you're thinking of the FBH, Tim. The gearbox cooler is integral to the radiator. |
FBH fan is almost silent in my experience, this was a loud, almost like the engine is stressed, rushing noise that I used to get from under both the TDv6 and TDv8 RRS's that I owned, my current SDv6 has not (not that I have noticed) made it. It literally lasted 2-3 minutes after pull away. When I queried it at the dealership I was told not to worry it was either something to do with the gearbox oil cooling or the VCU sensing the outside temperature ............ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
A viscous fan is fan that is driven off the engine/belt. It varies speed depending on temperature. Diesels have this. See If the fan is attached to the engine. |
I thought that a viscous fan worked using the same principal as the viscous coupling in the transmission- i.e. As the viscosity of the fluid in the coupling heats up it either thickens or thins and the amount of slippage due to the change of viscosity determines if the fan or clutch operates and the amount that it engages. I comment on this as I recently had the viscous coupled fan on my Defender replaced at 20 years old as it wasn't cutting when the engine got a bit hot on the motorway........ and that was how the Indie who replaced it for me explained roughly how it works. The fan is run by either a belt drive or electrically and the viscous coupling is there to save power losses from the fan ruining unnecessarily
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 ![]() ![]() |
My understanding is that the fan (certainly on my TDV6) is 'electro viscous'. In that, whilst it is a viscous fan it also has an electronic component to the coupling that is controlled by an ECU. Sometimes when the engine is cold it takes a while for the ECU to gather its required info and so resorts to its default setting i.e. fan locked up for maximum cooling. I experienced this on my RRS so researched the topic as I knew the fan was viscous and therefore, to my previous understanding, must be faulty. Fortunately that was not the case!!
