Home > Faults & Fixes > RRS V8 Issues after long not drive
SeQ
Lithuania 2007 Range Rover Sport TDV8 HSE Java Black
Hello,
My car was in airport parking place for 9 days.
then i started it - all was fine.
went for ~120 km, stopped for a coffee in gas station.
Started engine and got
Computer gives these errors:
Basically these errors could not be deleted:
1. P132B - left side turbo geometry is stucking
2. P2008 - left side input colector geometry is stucking
3. P0A15 - motor mounts control is not correct.
3 point i think is related to that after i get engine fault mottor starts making lots of noise.
the other thing is that, if i start cold engine then no errors appear.
but after i turn off and start again (hot engine) then i get error and car has no power..
any ideas?
could it be Vacuum problem or other problem?
Post #512198 Tue Dec 13 2016 1:00pm
Camelrock
Sounds like sticking actuator on left turbo. Might be worth spraying plenty of lub and working it, see if it frees off 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #512199 Tue Dec 13 2016 1:30pm
SeQ
could it be selenoid (electrical valve) ?
the thing is that if i start cold i can drive milions of km Smile
but if i stop, turn off and after i.e. 1 min turn on and start it starts making noise, motor works very loud and no power. and of course error appears.
Post #512200 Tue Dec 13 2016 1:37pm
