Home > Maintenance & Modifications > Help please. Steering fault. Play in steering wheel
4rron
England 2006 Range Rover Sport TDV6 HSE Stornoway Grey
Hi, I have spent I while searching for a solution to this problem but can't find anything similar.
I was getting a clicking sound from the steering column area when turning the wheel. It didn't have any particular place in the turn it did it and got progressively worse. It has suddenly stopped and I now have about an inch of play in the steering. It sounds to me like something's failed/snapped. My garage have just said they don't know what it is but suggest replacing the steering column at the best part of a grand with the part being 600 on its own.
Does anyone have any Ideas? I have seen a second hand steering column for £40, would this be an easy fix?(obviously it is an unknown quality of part but I doubt it will have this problem)
Post #512115 Mon Dec 12 2016 10:59am
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Look at this
http://www.disco3.co.uk/forum/topic56798.h...teering+uj 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #512117 Mon Dec 12 2016 11:19am
4rron
Thanks, I have seen that thread but it doesn't quite fit my problem. My steering has never been heavy, it was just a claim cling sound followed by play in the steering wheel.
Post #512119 Mon Dec 12 2016 11:42am
Jase3983yorkshire
2010 Range Rover Sport TDV8 HSE Santorini Black
I have just had my lower steering column replaced which cost £156 and i hade the same symptons as you about an inch play in my steering wheel. Now the car feels like new and a totally different driving experience as you can imagine, The part is the UJ (universal joint) i believe. TDV8,Black, Black Heated leather f&r, Rear Entertainment with Headpones & Remote, TV, DVD, Dab Radio, Sidesteps, Adaptive Headlights, sunroof, Heated steering wheel,tow bar,autobiography kit,piano black interior.rear camera, extended leather pack,adaptive cruise control.
Post #512153 Mon Dec 12 2016 8:33pm
Bodsy
Site Sponsor
My money would be on lower steering column. Sounds like it's really really properly broken to almost falling apart..... Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #512169 Tue Dec 13 2016 12:02am
4rron
Thanks guys. £160 is a better starting point than 1000
Post #512174 Tue Dec 13 2016 7:41am
4rron
Turns out it needs a new steering rack.£2200 or a refurb £1100
Post #519264 Tue Feb 28 2017 8:21am
Socast
Change the lower steering column too, it is a bit of a weakness and will no doubt need doing anyway. Far easier and cheaper to do it when the steering rack is being replaced.
Post #519266 Tue Feb 28 2017 8:45am
