![]() | Home > General (L494) > Engine Oil Level Sensor Failure Warning |
Not sure that I need LRA now............... just been out and started the and moved it and no warnings on the dash! Will have to keep an eye on it over the next few days and see if I get the warning again. Won't it be great when ICE vehicles are all done away with and all we have to worry about is charge level in the battery ..................... or water getting into bits that it shouldn't.... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 ![]() ![]() |
Exactly the same - except it was a nice sunny day about a month ago and I only had a few miles to go!
Thanks Peanut, I don't have any issues with stop/start and used it while driving home last night and stopped at traffic lights where we have roadworks on the local country roads (must be getting near to the end of the council's financial year and they have to get rid of money as we have had hundreds of small road works suddenly appeared but no money seems to be being spent on pot hole repairs..........) and it worked fine. I've never noticed the RRS or previous two cars fitted with a DPF doing a regeneration - maybe all my local fast A road driving means that the system doesn't need to run or does it so I don't notice it, I rarely do stop start town commuting type driving which also helps. My oil level has always read maximum on the dash gauge but at the first service the servicing dealership assured me that it was correct and not to worry so I haven't, until now! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
Hi Peanut, I had exactly the same issue. Auto stop/start not working. I was fobbed off with, "you don't do enough miles to keep the battery at full charge, power management system shuts down auto stop/start first as part of its power saving routine, Its a characteristic with low mileage drivers" etc, etc. I used to call it the most expensive PHEV manufactured as you had none of benefits and all of the drawbacks of such a vehicle having to pug it in to the CTEK on a regular basis to keep correct voltage in the battery for everything to work as it should! However, had a major power problem recently and the car wound up back at the dealers who installed Q634, which is related to a power management module software update and all these problems appear to have now gone away. It is a recall item, so suggest you book it in with the dealer as soon as convenient. Doesn't help you at all Tim, but has made a very positive difference to me! Regards, Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles. 2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten. |
Mine had Q634 while it was in for investigation of the front screen defroster failure and even though I had had no issues prior to the update I noticed that the throttle response was much more sensitive after having it, more instantaneous, no hesitation to pull away when you want a quick pull away from a junction. It wasn't bad before but much improved since! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
