Home > Technical > Drivers Side HOT / Passenger Side COLD |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Throw it back at the dealer you bought it off....? Visitor from fullfatrr.com
Tue Dec 06 2016 5:37pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
You can try this
Tue Dec 06 2016 5:43pm |
Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42 |
It is probably the Servo motor on the lower left side of the hvac box at the bottom of the center console. Check the lower motor on the left side. Your passenger side. Mine died and I am waiting for a new one. You can remove the motor fairly easily. you can manually flip the flap that diverts the ac and heat on the left side of the truck. Phil
Wed Dec 07 2016 6:30am |
