Home > General > SVR Carbon Fibre vs Dark Engine Turned Aluminium Interior
jrpl2811
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Just about to build lock on my SVR and I'm torn between standard interior finish and the carbon fibre veneer.
Does the CF look a bit "much" and, conversely, does the dark aluminium look a bit "bland" when you compare with the CF?
The one I test drove had the aluminium and I wasn't blown away by it. I did ask about them putting the piano black in for me but it was going to add about £3k and extend the build time by a few months.
Any opinions greatly received!
Thanks
James
Post #511374 Fri Dec 02 2016 1:45pm
Lyonhead
Wales
Hi James,
I've got the Carbon Fibre interior on mine and to be honest it really sets it off. Steering wheel, Centre Console, Air vents and doors, I do get a lot of comments about it. Also I went for the Carbon Fibre engine cover as well, maybe a bit over the top as no one sees it but I know it's there and makes me smile when I lift the bonnet.
I've had Carbon Fibre on the outside as well, grille, bonnet vents and side vents and rear door strip but went with another company as LR wanted absolutely extortionate prices. Thumbs Up
Post #511376 Fri Dec 02 2016 2:17pm
