![]() | Home > Maintenance & Modifications > Steering wheel upgrade to 2010 type |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 ![]() ![]() ![]() |
I have a 2005 first edition S/C, really want to do something with the steering wheel as it looks and feels awful.
I did this mod. way back on a 09 pre facelift car, used all new parts heated steering wheel, switch packs etc. the only part you cannot get to work on the pre facelift is the r/h menu button on the latter steering wheel athough you can make both left and right buttons work the audio controls.
Thanks Col, I won't be using any new parts. Will I need a clockspring off a 2010 MY and will the early cars connectors fit. Life's too short to drive boring cars !
You will need the later clockspring but make sure it is the latter one with the heated wheel connector, according to parts lists all facelift cars had it fitted wether they had heated wheel or not but judging by other post this is not the case.
Thanks Col
No, did not need to programme or enable anything to get the paddles or any of the switch packs etc. to work once the new circuit boards had been fitted.
Did you wire in the paddles shift direct to the gearshift module,
The wireless reciever is spliced into the wiring harness under the center consol by the gearstick. A wiring diagram is included with the kit from BBS.
