Home > Faults & Fixes > range rover sport hse 2008 L320 2.7 Heating problems
Schizz
Italy
Hello to all,
this morning in my house there are -3 degrees, turn on the machine, but to heat the passenger compartment takes at least 8 km and about 15/20 minutes.
when I arrived at work I opened the hood and Webasto was working.
You also have this problem? if yes how you solved it?
Thank you
;O)
Schizz
Post #511135 Wed Nov 30 2016 9:45am
Bodsy
Site Sponsor
I fit a remote control for the FBH and then you can warm the car up sooo much quicker.
I can post to you also, no problem. Three wires to fit, runs on GSM sim so you just text or call or use the web app to activate it.
-6 outside this morning, -2 registered in the FBH. After 30 minutes, 72degrees so the engine is warm when you start and gets up to running temperature very quickly. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #511142 Wed Nov 30 2016 11:05am
Schizz
Italy
thanks send me if you can do everything to this mail
audioste@tin.it
thank you !!!
Schizz
Post #511143 Wed Nov 30 2016 11:08am
Bodsy
Site Sponsor
Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #511144 Wed Nov 30 2016 11:14am
