![]() | Home > Maintenance & Modifications > iPhone connector??? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
enable Bluetooth on the phone.
If there is no B/T then I can recommend retrofitting a Parrott in car hands free phone system, they are much more versatile than the RRS system from 2007. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Richard039 Member Since: 17 Nov 2016 Location: Surrey Posts: 29 ![]() ![]() ![]() |
Hi
If the Nokia is underneath the armrest cubby lid, then it's the factory kit, which includes blutooth.
Hi
I have tried using several different phones and none of them can even find the Land Rover connection so I can't even attempt to pair with it.
You could get a free sim from ASDA for it. (order on internet). Comes with 10 free minutes.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
I dont believe you cant use the two systems at the same time, remove the phone from the cradle, wait a while, then try the BT pairing again 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Thanks for that your suggestion worked |
typhoo12 Member Since: 10 Nov 2016 Location: United Kingdom Posts: 40 ![]() ![]() ![]() |
Mine isnt finding the "landrover" and just brings up handsfree. When i try to pair it says it needs to be within range and turned on to find? Any ideas what the problem may be? |
the Landrover BT module turns on with the ignition, if that is faulty then it wont connect, see if you can find a BT untit in a scrap yard or borrow one? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
To cut a long story short I started my RR up, took out the Nokia phone from the chubby box and waited about 5 minutes then I searched for the land rover and it worked. With the Nokia connected to the RR it wouldn't work. The hands free you've found is most likely not the RR. Hope this helps |
