Home > In Car Electronics > Tracker - After ignition live lead under the bonnet
ibartsimp
France 2007 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Hi
I'd like to connect a gps tracker under the bonnet.
Do you know where I can easily find a + after ignition (so as not to drain the battery full time)?
In advance, thanks a lot!
Post #510906 Sun Nov 27 2016 9:55pm
Green wire under the fuse box.
Post #510909 Sun Nov 27 2016 10:12pm
Bodsy
Site Sponsor
You want to install a tracker, but only works with ign on.....? Why....? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #510919 Mon Nov 28 2016 12:21am
ibartsimp
No it has a battery so it will only charge when ignition is on
Otherwise battery will be drained, no ?
Thanks for the green wire info
will look into that
Post #510925 Mon Nov 28 2016 6:24am
trackers are normally hooked up to a battery supply, which is the thing to do.
They used to have a fuel pump supply input too, so you knew if the engine was running from a remote location
Post #510943 Mon Nov 28 2016 12:04pm
ibartsimp
Mine is powered through a usb adapter so I have to add a 12V adapter and then hook the whole thing together.
THere's no immobilizer, it's a simple tracker.
Post #510964 Mon Nov 28 2016 4:20pm
ibartsimp
For the record, I may change my plan and use the 12v plug in the trunk, I just have to figure out
1.how to stick the gps & stuff behind
2.how to make sure that he gps switches on again after the battery dies if the car is not used for a while...
Post #511562 Sun Dec 04 2016 9:10pm
