Home > General > Auxiliary Heater |
Hutch41 Member Since: 19 Nov 2016 Location: Northumberland Posts: 95 |
Can someone answer this please......there is an auxiliary heater fitted to my car.
Fri Nov 25 2016 2:05pm |
Not sure if this applies to the later model such as yours but certainly on the models up to 2009 a snowflake appears on the dash adjacent to the temperature to indicate it is sufficiently cold to invoke operation of the auxiliary heater.
Fri Nov 25 2016 4:27pm |
radders1 Member Since: 22 Nov 2016 Location: Preston Posts: 12 |
Being one of those 'new Range Rover owners' I saw this smoke coming out of the near side this morning and did panic a little I must admit. Thank you for clearing this up for me without even asking |
Fri Nov 25 2016 8:40pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
http://www.disco4.com/forum/webasto-fuel-b...b999387d89 Visitor from fullfatrr.com
Sat Nov 26 2016 9:22am |
Thanks to everyone again.....very helpful bunch I must say. |
Sat Nov 26 2016 4:59pm |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 |
Unless I'm mistaken, the snowflake indicates that the temperature is low enough for a risk of ice, rather than that the heater has come on. Of course, they may both be triggered by the same temperature but I think the first reason is more useful. |
Sat Nov 26 2016 5:34pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
Absolutely.
Sat Nov 26 2016 6:28pm |
RallyXS Member Since: 07 Oct 2016 Location: Devon Posts: 82 |
When I read the manual I'm sure it said the FBH would activate below 8c. 2012 RRS SDV6
Mon Nov 28 2016 9:10pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9007 |
FBH activates at external temperature below 9deg C and with a coolant temp below 75deg C. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 28 2016 10:16pm |
Ha Ha.
Tue Nov 29 2016 5:40pm |
actually.... it's 5degrees....... Bodsys Brake Bible
Tue Nov 29 2016 5:59pm |
I got it from the Workshop Manual... 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 29 2016 8:22pm |
Just to resurrect this and show how nerdy some of us are, I read that the FBH won't activate if you have less than 1/4 tank of diesel. Well I was nearly down to reserve and mine worked, so that must be a myth. 2012 RRS SDV6 2014 BMW 320d X-Drive Touring 1999 VW Polo stage rally car |
Wed Jan 18 2017 8:39pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 |
I've heard that if you have a pink one it's 9 degrees, but if it's a blue one, it's 8 degrees.
Wed Jan 18 2017 11:21pm |
