Front suspension won't rise
Hi Guys, I have searched for my exact fault on the forum but still haven't come up with much luck so I was wondering if anyone could possibly help?
I've got a 2007 v6, the car was driving fine and then suddenly the front suspension of he car just dropped to its lowest level and my ride hide indicators were all over the place. Turned he car on and off again but only the back of the car will raise and i can't drive it over 30mph. I've taken it to a Land Rover specialist and they have plugged the car in and tested each air bag to inflate it and also replaced my ride heights sensors on the front, that failed to work so they then tried a test compressor on the car but still having the same issue as the front won't raise. I've been told there's also no fault codes coming up either which doesn't help.
I don't suppose anyone can shed some light on this particular fault?
Thanks
Sun Aug 07 2016 10:45am
DrRob
Valve block on front needing a clean out?
Do a search on here and see if you find anything..... Visitor from fullfatrr.com
Sun Aug 07 2016 1:41pm
Edmundz1
That's great thanks!
Wed Nov 23 2016 8:15pm
Edmundz1
Oh sorry I forgot to write it ended up being the ride height sensor that had come loose from the chassis!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
