Home > Technical > Vibration on Overrun |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
Since I've had the car I noticed sort of gentle vibration on the overrun. As I had nothing similar to compare it with I put it down to a normal feature of the car itself. However, when I took it into my local indie for a check up (and without mentioning the vibration) he took it for a test drive and commented that the vibration was not normal.
Tue Nov 22 2016 4:04pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
In combination with the clunk , it might be a worn driveshaft |
Tue Nov 22 2016 4:16pm |
I have the exact same model and MY and have had that issue. The procedure your indie is suggesting is a 'double flush' and it makes sense to have it done; although there is a better procedure requiring special equipment whereby all the fluid is changed (usually referred to a a megaflush). Changing the fluid may help your issue but you should also get an expert to verify that your gearbox control module has the latest version of the software. Having the adaptations cleared and the clutches re-calibrated at the same time is usually recommended. What you have been feeling is the gearbox setting off in 2nd gear then responding to your big throttle input by downshifting to first. A combination of old fluid, out of date software and poor clutch calibration may be causing the rough shift you feel. A combination of the above plus a bit of servicing cured the issue on my car.
Does the vibration on overrun occur when say you are slowing down from high speed quite quickly like on a motorway off ramp and feel similar to that a flat tyre makes? When mine started doing that it turned out to be a front differential. Premature front diff failure is a known issue on cars of that era. Expensive fix if you buy a LR sourced rebuilt diff at over a grand. There are places that offer in-house rebuilds for less money. IAWA 4x4 in Northants has beenn mentioned a few times. Hope some of that helps 2008 MY Java Black TDV8 HSE |
Tue Nov 22 2016 4:31pm |
Brilliant guys - thanks for the info . Where I am now:
Tue Nov 22 2016 6:08pm |
Update on my issues:
Thu Dec 15 2016 3:46pm |
