Home > Technical > Gearbox Clunk |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
I've had my RRS since March 2016 and noticed that there is a clunk when reapplying power after say you slowed down at a roundabout and then applied a fair amount of power (say 25%) to get moving fairly quickly. Its as if it hadn't pre-selected the correct gear and clunked in when the power is applied. If you give it a couple of seconds, or apply very gentle power then clunk doesn't occur.
Tue Nov 22 2016 4:00pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
It might be a mechanical issue as well. However if you have the gearbox drained again, have it flushed and also have the filter(which is integrated with the oilpan) changed. succes1 |
Tue Nov 22 2016 4:14pm |
Cheers Guys - just the sort of feedback I was hoping for - and thanks for the PM Dr Rob Robin
Tue Nov 22 2016 5:59pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
The car does have a natural 'hesitation' under the circumstances you describe. Essentailly the car is in second gear as you are slowing towards stopping and as you apply the power in order to get away a bit quicker the car 'kicks down' to first gear. This is normal for the RRS.
Tue Nov 22 2016 6:22pm |
Thanks for that Russben. I understand what your driving at and to be frank, now you mention it I'm not sure. As I've just been hitting the scotch 🍹I can't take it out to check now ( hey, the sun's well over the yardarm). But when out tomorrow I'll make a point to check. Good thinking though!👌 Robin
Tue Nov 22 2016 7:16pm |
No problem & happy to help.
Tue Nov 22 2016 9:13pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
I battled with this for long enough on my own car. Eventually traced it to a worn front prop |
Tue Nov 22 2016 9:40pm |
