Home > General (L494) > Dripping from the boot?
somchie
Sweden 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Is it normal having water dripping from the "boot close"-button surrounding?
It usually drips from the rubber knobs on both sides of the boot but it has started to drip form the middle as well making it hard not getting wet when accessing things in the boot.
I uploaded a picture of this in my gallery!
Post #414960 Fri Feb 21 2014 3:29pm
doohickey
Northern Ireland
just looked at your photo I have same problem, did anybody go back to dealer about this
Post #510028 Mon Nov 14 2016 11:18am
wilf
Mine certainly does not drip from there. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #510037 Mon Nov 14 2016 1:00pm
gnasher
I did a previous post on this. Don't ignore it. It's a problem with a trim seal which they get at from the inside.
It can cause electrical problems if left to build up.
Post #510111 Tue Nov 15 2016 4:39pm
doohickey
Northern Ireland
do you mean a seal on the door itself
Post #510118 Tue Nov 15 2016 5:34pm
gnasher
Not on the outside. It was somewhere inside the lower tailgate panel..just take it to the dealer, they sorted it fairly quickly.
Post #510123 Tue Nov 15 2016 6:09pm
Renaco
I had exactly the same problem and they fixed it last week.
The water comes from the tailgate trim above the license plate.
It finds the way thru the openings for the clips and they just remove the trim and fix it back with silicone to solve it.
Newer models got an updated design/seal for this trim openings.
Post #510146 Tue Nov 15 2016 9:43pm
maci234
Newer models got an updated design/seal for this trim openings do you know anymore about this
Post #589331 Sun Oct 27 2019 11:06am
