Home > Technical > split boot
sportdaz1971
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
split boot
hi guys iv just moved over from disco3 to rrsport after swapping my d3 for an 07 plate rrs hse which i love ,only one question is i can't open the split boot door ,the top half .the whole boot opens fine but just the top won't open .pressed the open button inside but still nothing. as the mechanism gone or is it me.cheers and thanks .daz
Post #509996 Sun Nov 13 2016 9:18pm
The switch can corrode and become unserviceable. It's an easy fix, thankfully. Have you tried pressing the Land Rover switch on your key in case it has been set to release the glass boot? 2012 SDV6 - it's missing a couple of cylinders
Post #510004 Sun Nov 13 2016 11:32pm
sportdaz1971
cheers for getting back rrstdv8 tried the keyfob bottom button but just opens the whole boot again .think i will get in the garage at weekend see if they can sort it out ,cheers for you help.daz
Post #510052 Mon Nov 14 2016 4:55pm
Eaters
I have a similar problem with my tailgate glass. It's on my list to replace the switch which I understand is an easy job. However it's low priority as I can open the glass with the 3rd button on the key fob so not an urgent issue. I have found that if I really squeeze the tailgate switch, it does work hence my belief that a new switch will sort it. You might want to try a hard squeeze of the switch as part of your investigations. However it will probably only confirm that a new switch is needed. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #510062 Mon Nov 14 2016 5:48pm
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
There is a micro switch behind the rubber cover, this has a small metal strip across it that corrodes and disintegrates.
If you feel around up in there you will feel the micro switch. if you don't want to fix straight away but can activate the switch you can re-programme the key fob.
Its a very simple repair, and not costly.
Post #510072 Mon Nov 14 2016 6:38pm
sportdaz1971
cheers for the help jack sparrow will try that 2moro when i'v got some day light ,hope this works. Thumbs Up
Post #510076 Mon Nov 14 2016 7:17pm
Cpt Jack Sparrow
how did you get on?
Post #510133 Tue Nov 15 2016 7:32pm
sportdaz1971
hi mate not got round to it till weekend ,the wife not in till 6.45 every night from work by then its pitch black .i only get have a drive and mess about with it at weekends Sad .will let you know if i fix it or not .cheers daz.
Post #510183 Wed Nov 16 2016 2:25pm
