Home > Technical > Main Beam Warning Light.
rrgrandad
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
The blue main beam warning light on my 2006 RRS is not working. Does anyone know whether this is a replaceable bulb or whether a whole new instrument cluster is needed?
Any advice appreciated.
Post #509893 Sat Nov 12 2016 11:46am
Paddi
It might be worth getting the fault codes read first to find out if there is a problem with a module or wiring - don't just assume it is a failed light.
The lights behind the instrument panel are LEDs on a printed circuit board. If it is a failed light and you can handle a soldering iron perhaps you could find replacements from a Chinese supplier or get hold of a salvage panel to cannibalise and make a repair?
Our friends at Powerful helpfully posted these videos showing how to remove the instrument panel and dismantle it:
Alternatively there are specialists who can repair your panel for you. 2008 MY Java Black TDV8 HSE
Post #509905 Sat Nov 12 2016 3:46pm
