Home > In Car Electronics > FBH remote control
Plazmapete
FBH remote control
Hi. I have been reading about this FBH remote control unit.
Is it not just a remote control that puts 12 volts on a timer for 30 mins into the FBH? Isn't £200 a bit steep?
I have found one that's less than £40 that will do the same job.
Or am I missing something???
Post #509781 Thu Nov 10 2016 6:38pm
Bodsy
Site Sponsor
If only it was that simple.....
the webasto heaters use a specific signal type W-Bus to communicate with the FBH and get status and fault info as well as other info. 12v signal won't work I'm afraid. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #509792 Thu Nov 10 2016 7:23pm
andywatson
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
For what Bodsy charges for this set up, at a time and place of your choice and the peace of mind that further costs won't be around the corner - its a no brainer Thumbs Up
Oh - and is it worth it -YES! Very Happy 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #509814 Fri Nov 11 2016 8:02am
Jase3983yorkshire
2010 Range Rover Sport TDV8 HSE Santorini Black
I had this fitted today from bodsy who i can genuinely recommend, hes very professional and his knowledge is excellent. I had a few questions regarding my motor in general which he always had an answer/advice for. I will def be using his services again when hes next up this way. Very Happy
Post #509839 Fri Nov 11 2016 2:25pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
See Bodsy, don't mess around Thumbs Up I believe has set more of these up than NASA Very Happy 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #509867 Fri Nov 11 2016 9:48pm
