Home > General (L494) > On My Third Set Of Wipers!
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Mine has this issue. The region is the overlap between the arc of the two blades, and I susepct the slight difference in curvature between the blade and the bottom of the windscreen, where there the driver's side blade sits for most of its life, contributes to the cause.
Post #499760 Tue Jun 28 2016 2:43pm
rangiejools
Australia
BigBen wrote:
Had this smear problem from new ( over 2 years) and tried all the suggestions on this site to remove problem. Just changed the wipers for a set of Bosch Aerotwins and problem has virtually gone immediately. IMO a much better blade for half the price of OEM.
Big Ben, Be interested to know if you still have a clear windscreen in a couple of weeks. Every time mine was "fixed" it came back. RRS P460e
1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired.
Many big trips done in this one.
1982 Rangerover nearly restored.
22 Defender D250 with lots of stuff for outback touring
Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad!
2013 Land Rover Defender ute.
Post #499803 Tue Jun 28 2016 10:00pm
BigBen
Will let you know.
Post #499845 Wed Jun 29 2016 4:16pm
Renaco
After 65.000 km and 3 sets I found the perfect blades and I am very impressed.
Better than original and better than Bosch Areotwin is the SWF Visioflex, as the Blade is thinner than all others around an the aerodynamics are far better.
I took Article code 119764, this is for the two front blades for left hand drive, 24" and 21", that's bit larger passenger side blade, perfect working and a wider view now.
I am sure there must be a similar left hand drive code, look for Mitsubishi ASX from 7/10 onwards.
Best René
Look is OK:
Post #509546 Mon Nov 07 2016 8:51pm
Humbug
Had same problem – long smear in lower, middle screen from tip of driver's wiper – and changed blades over 18 months ago but different outcome as no repetition.
Also had a chipped windscreen replaced soon afterwards so maybe the problem is in slightly imperfectly shaped glass which blades can't cope with as they lose their initial suppleness? Some say chips are common because the screen is particularly thin and light, so could also be less easy to shape perfectly (maybe I've been lucky with my replacement) and would explain why Aerotwin blades work as I assume they're designed to be pushed to the glass most efficiently.
Post #509576 Tue Nov 08 2016 9:53am
rangiejools
Australia
I tried Aerotwins. Smudge came back after a couple of weeks.....I reckon it is the windscreen! RRS P460e
Post #509719 Thu Nov 10 2016 5:34am
PetesRRS
Australia 2013 Range Rover Sport SDV6 HSE Fuji White
I have the infamous smear as well
Post #509722 Thu Nov 10 2016 6:07am
wilf
You can get a test for that. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #509729 Thu Nov 10 2016 8:50am
rangiejools
Australia
A test for what Wilf? RRS P460e
Post #509734 Thu Nov 10 2016 9:08am
wilf
Can't have been that bad a joke? "Smear test"? Geddit?
Maybe it's me.....................it often is. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #509740 Thu Nov 10 2016 10:24am
Renaco
By the way, driven 3 days and 2500 Km in rain, its "the test", and the SWF blades are better than oem.
"But" think its not only a blades or window problem, it is the wiper arm, it doesn't give enough pressure down.
Will check this weekend the pressure compared to other cars...
Post #509744 Thu Nov 10 2016 12:07pm
