![]() | Home > Technical > Supercharged front O2 sensors problem! |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
If you've changed the sensors it could be dirty or corroded contacts on the wiring. |
Unclebuck Member Since: 04 Dec 2014 Location: South Yorkshire Posts: 51 ![]() ![]() ![]() |
Thanks for your answer , Do you mean the wiring in the grey multi plug that connects to the sensor ?[/quote] |
