Home > For Sale & Wanted > Found!!! Land Rover Winch Sump Guard |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Adding a winch next then? Bit serious!
Sun Nov 06 2016 6:42pm |
maybe!!! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Nov 06 2016 8:03pm |
Mon Nov 07 2016 3:59pm |
They are different from what i am led to believe, so i might end up redesigning my mantec one! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Mon Nov 07 2016 4:15pm |
Bump 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Nov 20 2016 7:00pm |
Now have one of these in my possession after collecting it from a chap in Milton Keynes today, needs abit of a pressure wash but otherwise it's tiptop. Genuine L/R one too made by Mantec
Thu Dec 08 2016 1:32pm |
Well done I have not seen any advertised yet
Thu Dec 08 2016 4:01pm |
Possibly riverblanche but not for a little while yet as I'm still on the look out for alot of other parts!
Thu Dec 08 2016 6:52pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I bet the LR Experience HQ might have some bits lying around.... Visitor from fullfatrr.com
Fri Dec 09 2016 11:12am |
That'll never fit an M5!
Sat Dec 10 2016 8:38am |
thanks Wayne
Sat Dec 10 2016 9:21am |
Synthetic better I think. Safer too Visitor from fullfatrr.com
Tue Dec 13 2016 6:50pm |
Much much safer and next to no maintenance unlike a wire, also while they do snapback when they part it is way less dramatic and dangerous than a wire breaking. Do be careful to wash out any sand / grit that might get into the heart of a synthetic rope as it can cause the strands to get frayed, also good practice to keep it covered when you are in strong sunlight as UV can degrade them which weakens them. I have had two 30mx 9mm in 8 years - first one was parted when recovering a careless Def90 from mud up to the waistline and the winch rope was only a year old ........... I replaced it with an Orange G4 rope from the local supplier who imported them for LR's Challenge cars and that is 11mm and is now 7 years old and has never been covered up on sunny days but I do run it off the barrel once a year in the winter and soak it to remove all the mud and sand deposits. I have a Milemarker Hydraulic winch - pulls and pulls, needs no special batteries or split charge system and doesn't disolve into a heap of steam and smoke when you most want it BUT it is very very slow although it has never given up on a recovery except when the rope parted! One thing you need to be careful with if replacing a wire with a Dyneema synthetic rope is that you replace the fair lead if it has been used for wire previously - wires can grind into the fair lead and if you then put a dyneema through it it will just chew it up, shortening it's life. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Dec 13 2016 7:19pm |
My thoughts to Rob
Tue Dec 13 2016 8:33pm |
