Home > Technical > Hydraulic fluid leaking above rear axle
Stead
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I have recently noticed a leak of hydraulic fluid coming from above the rear axle the look to be some sort of hydraulic pump got no hproblem with the vehicle but have just started noticing The leak any advice would be grateful it is a RRS 2009 30. Tdv6 thanks
Post #509420 Sun Nov 06 2016 10:25am
Sounds like you have the dynamic anti roll bars and the rear one is leaking. If it's just the connector that's leaking you may be able to get it repaired. If it's leaking from the main body of the bar then I'm afraid it's a new anti roll bar. That'll be £1000++ fitted! Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #509432 Sun Nov 06 2016 2:32pm
Stead
Thanks for the help yes it do look as if that is what gone has anybody ever replace placed one if so any advice
Post #509450 Sun Nov 06 2016 6:23pm
I think you have to lift the rear of the body by a few inches to replace the rear bar. Could be DIY, I guess, but it's going to be much easier on a ramp. 2012 SDV6 - it's missing a couple of cylinders
Post #509452 Sun Nov 06 2016 6:35pm
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Yes mine was done earlier this year. £1600 fitted. Half was cost of bar and half labour. My warranty paid half. Ouch all the same
Post #509463 Sun Nov 06 2016 8:52pm
Timf
Sorry it was a bit less. £1400 total
Post #509465 Sun Nov 06 2016 8:55pm
