![]() | Home > Maintenance & Modifications > Exit lights on bottom of doors |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I replaced mine with LEDs all round, it's worth cutting into the housing a little then you can fit a panel with either 8 or 12 LEDs rather than a single.
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
perfect.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Do the canbus ones used in the interior lights fade correctly? Robin
Hi
Cheers Riverblanche. Robin
Blueskye1 Member Since: 10 Sep 2016 Location: Carmarthen Posts: 80 ![]() ![]() ![]() |
Replaced mine as well |
Not having fitted them yet but I would suspect it is just that the bulb is located at one end rather than centrally. I have seen replacement kits which have LED right across the length of the holder. More expensive but might be worth a try in the future. I'm also wondering about the coloured option for the foot wells. Anyone tried them? Robin
Thanks
Answer to the problem I posted & solution |
I've just purchased and fitted these: http://www.ebay.co.uk/itm/272128114698?_tr...EBIDX%3AIT
Just replaced number plate lights with LED's ![]() I had replaced front door lights with LED's but as posted before not happy with only half being illuminated reason in pic so will replace with full LED's as shown in luggage area ![]() ![]() ![]() Rear doors to be done soon old yellow still fitted very poor ![]() ![]() ![]() ![]() Andrew ![]() Java Black 2.7 Date of first registration 22 February 2008 Cousin of the King of Stamford Bridge R.I.P. Ossie |
I can understand where you're coming from Blueskye1 and it may well be that I'll move on to the full LEDs but for a fiver I thought I'd give them a try. Looking forward to dark to see the improvement.
Eaters.. |
