Home > Technical > Squeak and a knock front suspension,possibly ARB bushes?
chopperneil
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Hi All,
I have had a annoying squeak from my front suspension now and again for a few months now and also get a slight knock from the front suspension on potholes etc, my car has the dynamic response and hydraulic ARB fitted (I believe). I spoke to my local dealer who said that it was £300 for replacement ARB bushes, is this correct? Im happy to spend that if it will cure the issue! but not sure what the dynamic response and hydraulics make to the bushes and what needs to be done to them if any?
like many others my hydraulic ARB has a very slight weep, but it is very slight, i havent had the need to top it up in 10k miles
thanks all
Post #509002 Mon Oct 31 2016 12:50pm
GodivaNige
I paid a local LR Independant £180 to replace the front ARB (with ARC) bushes using genuine parts, it cured both the symptoms you're suffering
Post #509003 Mon Oct 31 2016 1:01pm
chopperneil
Perfect, thats what I needed. Will see if the local indy can beat the main dealer and if not main dealer it is
Post #509007 Mon Oct 31 2016 1:41pm
chopperneil
Booked in for next friday at a local Indy (Dakar in swanley) £202
Post #509064 Tue Nov 01 2016 9:45am
RobP
Dakar are a good bunch Thumbs Up , even got a recommendation to use them by Beadles in Sidcup TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #509200 Wed Nov 02 2016 11:11pm
