Home > General > MOT Advisory |
m8ch1n Member Since: 26 Oct 2016 Location: Lancashire Posts: 28 |
It's a problem if it gives way with a full tank of fuel
Fri Oct 28 2016 6:36pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
They are a full tank cover on the RRS.
Fri Oct 28 2016 6:49pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Corrosion is fine. It's a big steel plate under the car, exposed to the elements
Fri Oct 28 2016 6:54pm |
Charliecloud Member Since: 21 Oct 2016 Location: Tonbridge Posts: 23 |
Thanks guys, I guess a good look will tell if it's as bad as the one in DM post |
Fri Oct 28 2016 8:09pm |
Just in case it's a replacement job, how much for a new one from LR
Fri Nov 04 2016 9:32pm |
RRS Genuine Fuel tank fitting kit, Part No.: DHB500370 is £70.96. Price from Rimmer Bros, but try our sponsors, such as Duckworth Parts, for a possible better price. Not sure if this is the correct part for your car, but gives an idea on cost, pipes, connectors etc are extra of course, as required. http://www.rimmerbros.co.uk/ItemSearch--se...r--srcin-1 John
Fri Nov 04 2016 9:51pm |
Not sure where that part number came from, but I make it a WFN500021, with a retail price of around £135 + VAT, plus the required bolts and captive nuts that will likely disintegrate upon removal
Fri Nov 04 2016 10:08pm |
Thanks guys- useful info |
Sat Nov 05 2016 9:28am |
